Interchangable Valances?
Discussion in 'Parts Interchange' started by Slider28, May 29, 2007.
  1. Slider28
    Slider28 Member
    San Antonio, Texas
    72 Maverick Grabber 302
    Im looking for a front valance for a 72 grabber.. are ALL front valances on a maverick from 69-77 2 and 4 door interchangable?? or even comets??
    thanks
    chaz.,
  2. 19BlacK77
    19BlacK77 Member
    The 74-77 models didnt have front valances, the 69.5-72 had valances with smaller openings, and the 73's had valances with longer openings. Any front valance from a 69.5-73 Maverick or Comet 2 or 4dr will work. Hope this helps you out.
  3. Slider28
    Slider28 Member
    San Antonio, Texas
    Thanks! Helps alot on the hunt!
    Chaz
  4. RabidCustoms
    just an FYI for the late model mav owners..an early valance will bolt right on to a 74-77 with no mods. should you want a spoiler without changing to small bumpers
  5. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Good looking out RadMav.
  6. Slider28
    Slider28 Member
    San Antonio, Texas
    I found a 73 front valance and the guy was a real maverick guy, and he said the 73 WILL NOT work on the 72.. can someone tell me if they have put a 73 on a 72 w/o mods??
    thanks
    chaz.
  7. Dave B
    The hole in the 73's is bigger to clear the front bumber supports.
  8. maverick1970
    maverick1970 MCG State Rep
    Missouri
    The 73 will bolt up but the turn lamps under the bumper will be sitting out in the open where on the 70-72 Valances they are at the edge of the opening.
  9. 75Mav91Stang
    75Mav91Stang Member
    Essex Fells, NJ
    1970 and 1975 Ford Maverick
    Does anyone have pics of the different ones? That would help out a bunch
  10. newtoford
    newtoford Member
    New Castle Delaware
    i just bolted up a 70' valance to my '76 fenders and it sits about 1'' too far foward and messes up the line around the wheel opening. it looks like im going to have to drop the valance and re-drill the factory holes so it sits further back. other than that the 3 holes them self on each side were perfectly spaced from one another so all 3 matched up with a fender hole.
