intake?
Discussion in 'General Maverick/Comet' started by HOMERMAV, Nov 4, 2009.
  1. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    i just noticed these two holes on my heads should they be covered by the intake.do i have the wrong intake? will this cause a vacum leak.
    thanks john
  2. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    no
    brad:)
  3. justin has a 74
    kentucky
    wow... Anyone care to explane???
  4. Bryant
    does any exhast come out when running. if so then something needs to be done. if not then i have no idea what those are.
  5. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    no exaust comes out but i can hear lifters until i cover the hole then it goes away.i think i will spray some starting fluid there to see if it increases rpm if not i will just leave them alone.i will keep everyone posted to what i find thursday.
    john
  6. mean_maverick
    that's for emissions crossover... shouldnt hurt anything to leave them like that, and it wont suck air or anything
  7. bradleygt
    bradleygt Member
    1970 maverick
    thats just a dead end hole going no where
    brad:)
  8. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    ok thanks guys
  9. blugene
    When spraying to find leaks it may be hard to notice with rpm's already high.
  10. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    when it warms up i can get the idle down when i open the manuel choke all the way up.in the duels video the motor is still choked.
  11. blugene
    How many turns you got on that screw? Looks like it's out a bit. :huh:
  12. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    yeah i think its almost all the way out so only a couple of turns.still when its warmed up i think its idleing to high.i need to install my tach so i know for sure what rpm im running. also need to do a final timeing check.
  13. blugene
    Others will probobly correct me but I think it should be screwed in till it stops and turned out 1 1/2 to 2 turns as a starting point. Then you adjust with a vacuum guage, providing no leaks and timing is correct ect...
  14. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    i think it needs to be all the way out then turned in one and a half to two turns.if i turn it all the way in first it will open up the throttle wide open.i think.
  15. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    I think Gene is thinking about the 2 idle screws on the front of the carb.
    But I might be wrong...so If I am Gene needs to yell at me :16suspect
