Intake cooling passages
Discussion in 'Technical' started by MiteeMaverick, May 22, 2005.
  1. MiteeMaverick
    MiteeMaverick Senior Member
    Jonesboro, AR
    1987 Mustang GT Convertible
    I am in the process of installing my Torker 289 intake on my car, the one I am removing has the rear cooling passages where the coolant can enter or exit the rear of the heads and I noticed the Torker 289 does not, it blocks them off. Will this make a difference in the cooling of my car? It runs at a steady 185-190 degrees all the time now.
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I never saw a difference with mine.
    I am not sure, but I don't think even factory intakes had a crossover back there during the 60s-70s.
    Dave
  3. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    A lot of the Edelbrocks do that. I figured they wouldn't do it if it was a problem. Many of the Weiend intakes retain the crossover.
  4. RabidCustoms
    many aftermarket intakes dont have the crossovers,.... no point in heating the intake if your aim is increased performance.
    my old Shelby intake has no crossovers either,if it was ok for Carroll,.then...(y)
  5. igo1090
    igo1090 Member
    catonsville, md
    no problems with mine.
  6. MiteeMaverick
    Jonesboro, AR
    Thanks guys, I installed it yesterday and it still runs at 190 degrees. Although I do have a little stumble in the carb when I first go to take off now, maybe I need to adjust the accel. pump due to the single plane.
  7. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    Yup....you do.
