Insturment Cluster Removal
Discussion in 'Technical' started by Jamie Miles, Mar 7, 2005.
  1. Jamie Miles
    I took the 2 screws out and gave it a tug, but it dosen't seem to want to budge? Are there any other things you have to do besides takeing the screws out and disconnecting the speedo cable and wires?
    Thanks
  2. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    mine gets stuck on the dash sometimes, when i take mine out
  3. capt.redbeard
    capt.redbeard Member
    Brainerd, MN
    74' maverick 250 car converted to a 302
    I had to take out the bolts that held up the steering column to get mine out, thier was not enough space for it to clear without a hammer (thats called a press fit)
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    May just be stuck from years of ???
    It is held in with 2 screws at the top and 2 tabs at the bottom. Pull out at the top only. You can try reaching up under the dash and push out on the cluster.
    You will need to disconnect the speedometer cable and wiring harness from the cluster.
  5. Jamie Miles
    Ok, thanks guys. I got it out. Tugged at the top a little more and it came out. Didn't sound to good, but I can't find anything broke so...
  6. courier11sec
    courier11sec Member
    Tucson, AZ
