instrument cluster
Discussion in 'Technical' started by fordness, Nov 29, 2017.
  1. fordness
    fordness Member
    forest hill, Md
    ford ranger & 75 MAVERICK
    Hey guys, My instrument panel speedo side lights up but the other side doesnt, everything works over there but no lights. IF anyone has fixed this problem let me know id greatly appreciate it
  2. yellow75
    Tillamook Oregon
    Will probably require you to take the cluster out and replace some bulbs or clean the contact surfaces, does the lights on the speedo dim by turning the light switch ?
    fordness likes this.
  3. Craig Selvey
    You might have the dreaded white plastic cluster, which is very prone to deterioration. This is usually one of the first signs it is starting to fail.
  4. fordness
    fordness Member
    forest hill, Md
    yes the lights dim by turning the switch. i also weeks ago went and got a new switch it was very affordable I guess i will put that in and then get new bulbs as well. Like i said everything works over on that side just not the back ground lighting but the lights for the signals and warning lights work just the background light behind it all and the gas gauge works too. thanks for replying buddy
