Installing harmonic balancer
Discussion in 'Technical' started by EFIMAV, Nov 9, 2006.
  1. EFIMAV
    EFIMAV Member
    Davenport Iowa
    I removed the FRPP balancer from the engine I recently purchased to change the timing cover. As expected I had to use a puller to remove it. Here is my question, how "hard" should this thing go on. When I slide it on the crank it slips onto the key just fine but then it stops sliding by hand. I think these things are tapered but I'm not sure. So, does this need to be installed by threading the bolt on? If so, the bolt I have will not work as it is not long enough to "reach" the threads. Also, it almost appears to be off center relative to the seal in the timing cover. Almost as though the key is forcing it off center. Maybe the seal isn't installed "straight". Everything appears to be fine as far as the crank and inside of the balancer is concerned (no marks or worn areas to speak of). Any thoughts.
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    rent/buy a harmonic balancer install tool , thats BEST way to do it, i installed mine w/o it , i slid the balencer on and put the bolt on and took the impact to it and it slid right into place , prolly not the best way but it worked
  3. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I've always just tightened the bolt to reinstall them ... You may have to tap it on a little until the threads reach ..
  4. eddie1975
    Martinsburg, WV
    sold
    im glad im not the only one that did it that way, it works the same way as a tool
  5. dmhines
    Cumming, GA
    Leave all the bolts on the time chain cover loose ... that way inserting the damper will center the cover and seal and prevent leaks ...
  6. don graham
    hard thing about using the bolt is stopping the engine from turning. checkers, pep boys and others have loaners. have to leave a deposit but you get it back when you return the tool.:)
  7. eddie1975
    Martinsburg, WV
    sold
    i didnt have any problem w/ the impact.... i can see problems w/ a rachet or breaker bar
  8. dmhines
    Cumming, GA
    I just stick a long socket extension in one of the spark plug holes to hold a piston ... keeps the engine from turning while tightening ..
  9. Scotty P
    Scotty P Member
    santa rosa, ca
    THat's good Dan! At the same time you can enlarge your valve eyebrows AND lower your too high compression. hee hee
  10. dmhines
    Cumming, GA
    The extension goes nowhere near the valves ... it lodges between the top of the piston and spark plug hole ... haven't ruined the plug thread yet ... :)
  11. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Use a rope or an old cut fan belt Dan. No scratches that way.
  12. bmcdaniel
    I bet your thrust bearing has a different opinion.
  13. eddie1975
    Martinsburg, WV
    sold
    uh oh , what do you mean?
  14. bmcdaniel
    The thrust main bearing in your engine keeps the crank properly located front to rear. They usually don't like to get hammered or "impacted". That's why they make tools to press on the damper. I've built quite a few small block Fords over the years, on every one I've been able to press on the damper using the bolt that holds the damper to the crank. That's with factory and aftermarket dampers.
  15. dmhines
    Cumming, GA
    I assume he meant "impact" wrench ... so it wouldn't have been hammered on ...
