Ignition upgrade
Discussion in 'Technical' started by Grabber5.0, Apr 13, 2005.
  1. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    With my erratic behavior when I floor it, particularly at high rpm, after checking other stuff I pulled the distributor to check the gear, and the teeth were worn to a very sharp edge. There's my high rpm gremlin. So it seems the bronze gear was not the best choice for the street, as I don't really want to replace it whenever I change my oil.. ;) I have somewhere between 2500 and 3000 miles on the motor. I know this has come up before, of course it was AFTER I already installed the bronze gear... :slap: I did have worries about how long the bronze gear would last, but sheesh, I thought it would be longer than that.
    As many miles are on my distributor, I know that could have been part of the cause as well. So I'm thinking it might be time to order me up a new ignition system. Any good arguments for something other than MSD ($ aside)? That's where I am leaning (6AL+pro billet or a ready to run). Have also considered staying with duraspark 2 and getting a recurved Ford dist, but would rather have something new not rebuilt.
  2. just1993
    just1993 Mike
    Zionsville, PA
    70' & 71' 2 Door and 76 4 Door
    MSD all way!! I have had 3 MSD set-ups had no problems. Are you running a roller cam in a 5.0. I was told you have to run a steel geer in that situation no matter what dist. you run. Went with a MSD for my 86 Mustang and had to get the gear changed for the roller cam set-up. Atleast that is what I was told.
    GOOD LUCK
    Mike
  3. Grabber5.0
    Kansas City, MO
    71 Grabber
    Yes. I didn't post that info because I'm talking about the motor in my sig.
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Matt I would call Comp Cams and talk to them about it. They have a composite gear but don't know if it would be any better.
    I have a full MSD setup and I am very happy with the exception of the type of connectors that they use.
  5. 2nd71Grabber
    2nd71Grabber Member
    I talked with MSD recently about running the same items you are mulling over on a 91 roller engine. The have a steel gear option on them to solve the compatibility and wear issues.
    What does your combo run in the quarter?
  6. stmanser
    Davenport, Iowa
    i bought the complete MSD ignition system.... Billet pro Distributor, MSD Blaster SS Coil, 6a box, 8.8 wires and I LOVE IT....
    it actually took .7 seconds of the 1/4 mile time for me.....
    getting it dialed in may be a pain but it is well worth it....i paid about 750 for the entire setup (and some extra stuff and i got it locally so i paid a little more)
    i priced it at summit.....for eveything i mentioned for $600 i think plus shipping...
    oh yeah...and i got it all installed in 10 hours....
    good luck....
  7. Grabber5.0
    Kansas City, MO
    71 Grabber
    I did call Comp Cams the other day, but I was not real impressed with the guy that I got ahold of. He did say the cam was compatible with the steel gear, but he used a term I didn't understand, and could not explain it -- i suspect because he was reading it from a screen and had no further definition.
    So far with the lack of tuning and traction available, the best I've managed is a 15.6. If I got what I paid for, it should be running alot faster.
  8. maverick1970
    Missouri
    Where did you buy the cam from?
  9. Grabber5.0
    Kansas City, MO
    71 Grabber
    I didn't buy it directly, the shop ordered it for the motor. Get this -- I called them again on the way home, and he said to run a stock cast iron gear because it isn't a billet core. :huh:
  10. maverick1970
    Missouri
    I was going to suggest you call them back or the Summit answer line. It amazes me that some companies survive with the level of service they supply.
  11. stmanser
    Davenport, Iowa
    i managed a 15.3 with out a MSD ignition....then i put the ignition in, got it dialed by my speed shop, put some purple gas in it and it ran 14.5
    i couldnt believe that it went that much faster with the MSD system, but they made me a believer...
  12. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    yeah MSD ignition setup 380 gears:biglaugh: trac bars e/t streets and a real carb ;) i bet it would get into the low 13s high 12s:162:
  13. stmanser
    Davenport, Iowa
    thats what i am shooting for....well into the 13's is happyness to me....i would be a very happy person for that...
    anything fast than 13.99 will be gravy...i dont want a purly track car...i want a daily driver that will whoop just about anything on the street...not that i will street race, but so that i can back up my mouth :)
  14. Grabber5.0
    Kansas City, MO
    71 Grabber
    Ok, this is interesting (at least it's getting more consistent :rolleyes:. I called Comp back up on the way home from work... this guy said it's not a billet core and to run a cast iron gear. Later this evening I called the Summit tech line, told him what cam I had, and asked what gear to use. Said to use a cast iron gear. I asked about the bronze gear and he said absolutely not to use that with this cam. He was surprised I got as many miles out of the bronze gear as I did.
  15. Grabber5.0
    Kansas City, MO
    71 Grabber
    I decided I need to spend the money on the Grabber worse than I do eeking out more horsepower from the motor, so I bought a Ford dizzy at Advance, and I'm going to order a 6AL box and Blaster coil tonight from Summit. I'll spend the big bucks for the MSD dist later on.
    One thing I noticed right away, the new distributor spins MUCH more freely than the old one. Seems to me that's something they should have noticed when they pressed the gear on but [​IMG] I am sure that was contributing to the problem as much as having the bronze gear in the first place.
