Ignition types/year of engine.
Discussion in 'General Maverick/Comet' started by Blackdog455, May 3, 2011.
  1. Blackdog455
    Blackdog455 Member
    Maple Valley, WA
    1971 ford Maverick
    I got my maverick almost three years ago and for the life of me i can't remember the year of the 302 in it. Im pretty sure the guy said it was an '88 but my dad remembers him saying its an '82...sooo yeah im at a dilemma because i dont want to have to take off the starter to look at the casting number cause i cant fit under the car.
    So is their any ignition out there (preferably MSD, Mallory, or Summit) that is sort of universal for the 302? Ive looked at MSD distributors and it seems as though some of them will work for any year 302. Just want some confirmation here is all!
  2. Mavman72
    Well...Any ignition system for a 302 will work...You need to determine if the engine has a roller cam/valvtrain or not....If its an all stock 88 5.0...Its most likely that its roller cammed but...Depending on what it came out of... It may not be. If its a stock 82 5.0...Its not a roller unless its been retrofitted with a roller cam. Its important since the roller cam set up requires a different alloy dist gear from a non roller...Good luck!!!
  3. Blackdog455
    Blackdog455 Member
    Maple Valley, WA
    1971 ford Maverick
    dang...ive always thought it was roller cammed...I asked my dad long ago and he said it was. now, for some odd reason that its not and i get a distributor that isnt made for roller cams, what would the outcome be?
  4. Mavman72
    The cam will eat the distributor gear and put metal shavings in your oil.
  5. Blackdog455
    Blackdog455 Member
    Maple Valley, WA
    1971 ford Maverick
    well...that is not good. This pretty much sucks.
  6. maverick75
    Except for the TFI setup, I'm pretty sure you need an EFI EMS to run that.
    I think 86+ had that, then also some of the last 302's didn't even have a distributor, they went to coil packs. Which also require an EMS.
  7. Blackdog455
    Blackdog455 Member
    Maple Valley, WA
    1971 ford Maverick
    Thats interesting. Its killing me not knowing what year this engine is.
  8. maverick75
    You can take off the starter and check the numbers, that'll give you a clue.
  9. mojo
    mojo "Everett"- Senior Citizen
    Even if u get the starter off and the engne numbers u will just have when the block was made; it won't mean the engine has not been modified/upgraded at some point. Why not just upgrade ign sys with present dizzy?
  10. rthomas771
    No...you will know what year the block was revised. The prefix didn't change every year. It would be easier to pull the distributor and look at the gear
  11. Bryant
    if you pull a valve cover and look down the push rod hole. you should be able to see if there is a dog bone holding the lifter. the top of the lifter will have two flat sides if its a roller. if its round then its a flat tappet.
  12. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    I'm saying?? Ding, Ding, Ding... correct answer goes to....:biglaugh:
  13. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Distributor should have a part number on it as well. But there is still a chance the gear was swapped.
  14. Blackdog455
    Blackdog455 Member
    Maple Valley, WA
    1971 ford Maverick
    I do know that when the guy rebuilt the engine, he only rebuilt the top end because the bottom end was in amazing condition. He said it came out of a police interceptor and its a High Output 302. The distributor is the original.
  15. bmcdaniel
    And roller cam pushrods are shorter than pushrods for flat tappets.
