ignition switch replacement HELP
Discussion in 'Technical' started by 72comet_GT, Apr 19, 2009.
  1. 72comet_GT
    72comet_GT Member
    Mahaffey, PA
    1972 comet GT
    I need to replace my ignition switch but cant figure out how to get to it. I read Chiltons instructions, and it simply states to remove the shrouding from the steering column....HOW! Looks like i have to remove the whole steering wheel. Can one of you smart guys explain please. Thanks
  2. maverick75
    IIRC u do have to remove the steering wheel and the key has to be on the "on" position, then theres a pin u have to press that u access behind the horn thingy gizmo.and it should slide right out.let me look for the instructions i got and i'll post a pic asap.
  3. Jamie Miles
    Alto, GA
    I've had a few
    Are you wanting to replace the actual electrical switch, or the tumbler where you put the key in?
  4. 72comet_GT
    72comet_GT Member
    Mahaffey, PA
    1972 comet GT
    Thanks Mav 75. I'm just replacing the switch.
  5. maverick75
    oops i thought you meant the tumbler,my bad.Heres the instructions I have for the switch,don't know if they're the same as the ones in your book.
