Idiot's Guide to Trim Removal
Discussion in 'Technical' started by MrPie68, Feb 27, 2009.
  1. MrPie68
    MrPie68 Member
    Midwest City, Oklahoma
    1969 1/2 Ford Maverick
    Ok, so after spending an hour using the removal tool and not catching the hook on anything but dirt and glue, can anyone please tell me what I'm missing here? I know there are "spring clips" but I'm just not catching anything. PLEASE HELP!! lol :banghead:
  2. scooper77515
    Which pieces of trim are you working on?
    Sounds like you got the idea down. Depending on which pieces you are working one, you may need to attack it from a different angle.
  3. Demmitt
    Demmitt nutz and boltz
    Sandsprings, Oklahoma,
    1976 2 door, 1969.5 2 DOOR
    there are bolts at the edges of each panel 3/8 (belt line trim) if i remember on my 76 and good old spring clips. around the windows its just spring clips. the trim on the door windows just slip on. pull like hell
  4. Bob Wiken
    Fayetteville, Arkansas
    Halo trim has a nut that you get to from inside and a screw from outside.
    lateral trim has nuts at the ends and spring clips in the middle
    Good luck.
  5. maverick1970
    maverick1970 MCG State Rep
    Missouri
    This might help
