I need info on my motor
Discussion in 'General Maverick/Comet' started by wjtkb, Jul 28, 2009.
  1. wjtkb
    wjtkb Member
    keystone heights fl
    maverick, 94 toyota pick-up, 94 honda accord
    If there is anyone out there that knows anything about a 1986 302 HO motor please tell me anything. im trying to rebuild it to put in my maverick and im trying to buy rings and bearings and i dont know the sizes or well anything at all about the motor. I will take any advice or information at all like the horse power torque or anything. thanks.
  2. Dave B
    Did you try the internet?
  3. mean_maverick
    unless your engine block has been bored, or the crank case been turned, then all of your bearing and ring sizes should be standard size (STD). and '86 engines are odd as they use flat top pistons so you have to watch valve to piston clearence. and if you're going to be running a roller cam, be sure to use the correct distributor gear.
    hope this helps some :)
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Why the new thread? I believe the 302 HO was rated at 200HP in 1986.
    First check you piston to bore clearances. If the block needs to be bored then the pistons will need to be replaced. Nothing special about the bearings. An auto parts store or machine shop can provide everything you need.
  5. tim keck
    sharps chapel,Tn
    Your car looks like that "12 second" one that was on e-bay awhile back.'86s use true flat top forged TRWs(no valve reliefs)and also use truck type(bad) heads.Get some E7 heads(87-up),and if it is still an EFI motor,you'll need an '85 GT dizzy and cam gear eccentric if you're gonna carb it.'85 was only year for roller cam/carb.Aftermarket also makes those parts to carb an EFI roller motor.
