well the problem os that my turn signal dont work right now and i already change the flasher and it still does not work i could use the help with this problem of mine THANKS
Sayien, Does the light come on and not blink or not come on at all. And is it both sides or just one?
If it was a fuse the turn ,running or brake lights would not work. It is possible a bad bulb if the signal light comes on on the instrunment panel and does not flash check both bulbs. If one of them is not lit up that bulb is bad. I have seen a bad new flasher unit before.
