i have a 75 comet and want to drop in a v8
Discussion in 'New Members Forum' started by 75comet, Dec 30, 2004.
  1. 75comet
    75comet Member
    keokuk, iowa
    1975 Comet
    questions about my 1975 comet and work to be done
    like the title says, i have a 1975 comet, wanting to drop a v8 into it, my dad says the biggestthat will fit is a 302 is that correct, he also says a 289 would be best what do you guys/girls think? Also i want to get bucket seats to put in. what all will i need for that? just the rails, and seats right? this is my first project car so im going to be askign alot of questions, hope you dont get annoyed
    thanks
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    If the car is a six now, your going to have to get a set of frame motor mounts for a v8, they bolt to the frame and the motor mounts bolt to them. Auto krafters did sell them, not sure if they still do or not. Can find them used if somebody is parting out a Maverick or Comet. Also will need a double hump trans crossmember if planning to run dual exhaust, again autokrafters has them at autokrafters.com. 289 and 302 are same size block, both will fit no problem with factory style parts, 351Windsor is wider, wiil fit but really close to shock towers, some guys cut the shock towers for spark plug clearance. I suggest staying with the 289 or 302, much easier swap for a first timer. As for bucket seats, you can make anything work if you try, some of the guys here have import seats, some other Ford seats, some have the custom racing style seats, it's just up to you and your ability to fabricate mounts and what you want in your car. Show us some pics!!! We LOVE pics!!!!!!:Welcome: (y) :ttiwwp:
  3. 75comet
    75comet Member
    keokuk, iowa
    1975 Comet
    ok thanks, i will get pics tomorow if i remember.
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Do the 302...
    It is essentially identical to the 289, just more cubic inches.
    After you get one bored and built, you will have at least 306 cubes.
    The 351w and 351c fit, but I would tell any newcomer to the hobby, "you don't want that project for your first project."
    Good luck
    Dave
  5. 75comet
    75comet Member
    keokuk, iowa
    1975 Comet
    pics can be found at http://fbcyouth.mjm88.com/comet.html ther you can see some of the body work i need to get done, and a side pic of the car, also the mounts that are in the car now
  6. 75comet
    75comet Member
    keokuk, iowa
    1975 Comet
    yep i did but thanks and im pretty sure i will need all the luck i need
  7. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    Welcome......Nice car.
    Luv pics!
    Iowa?????there is a few maverick/comet folks in that great state.
