I have 5 again...
Discussion in 'General Maverick/Comet' started by Mercurycruizers, Aug 21, 2005.
  1. Mercurycruizers
    Venetia, PA
    This has to be a sickness. I just purchased for $300, a 74 Comet GT 250 cu in, C-4. Still has the factory Slotted Mags & Mercury center caps. Blue with black accents. Vinyl top has been removed. Body is straight, very little rust, interior needs a little TLC. Guy said it needed points & battery recharged (has new Battery). He swore that it started a year ago & was moved to where it sits now. Got in turned key, no idiot lites came on. Turn key to start, nothing (not even a click). Took a screw driver to the starter solenoid & it turned over. Seemed to want to start, but no go. I'm not that good with electrical. Seems to me that something is not connected, maybe the yellow box under the dash, fuses. I'll have to check it out. I did check all the fusable links, they are good to go. Any ideas out there, as to where, to start looking? I need help....I'll post pics as soon as I take some. Hopefully tomorrow...
  2. MavMike
    MavMike Mile High Mav
    Denver, CO
    2 '70 Mavs, 1 '71 Mav, 1 '74 Grabber
    I'm having a similar issue. One thing I did do to rule out the distributor and coil was run a 12-14 gauge wire from the + battery terminal to the + coil post. If it fires up then the coil and distributor are probably good.
  3. Mavaholic
    If it has points, clean the hell out of them and regap. Will probably start right up after you run a jumper as Mike sugested. Since nothing is happening with the switch, maybe the rod came off and your not really moving the switch.
  4. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    when you try and start it, hold the shifter all the way in park.then turn key.took me two hours to find this out on daughers car.shift lever needed adjusted.
  5. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    I'd clean the connections on the starter solonoid also. I had one of the little wires loose connection once on my F100 and acted the same way.
    clint
  6. maverikrick
    maverikrick Member
    Nogales, AZ
    '74 2dr LDO V8 project
    Nice.
    Good score. To make you feel even better there's a 73 comet gt shell going on ebay right now for $455 with rust and other stuff missing besides the motor and tran.
    I just got a good score too, I just picked up a nice small rear bumber with the guards at junkyard for $45. Must have walked right past it 10 times before I noticed it.
  7. blondish
    blondish Member
    kansas
    neg.
    numbers
    Did you add your new purchase to the running totals of mavs on this site, whats that 501?
    Wendy
  8. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    Your right it is a sickness. I thought I was bad. Good job Coop. Go ahead and give it a complete tuneup and check to see if that is a good battery. If you can start it from the solenoid than it could be a battery. Good luck. If you need any help call me.
  9. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Well if its a sickness then we have a epidemic goin on here.
    Dan
  10. Mercurycruizers
    Venetia, PA
    Here's some pics before we clean it...Enjoy! I'll go add it to the post of counts.
  11. Corbin Johnson
    Corbin Johnson Member
    Sonoma County, California
    SWEET DEAL! For $300 you can't go wrong. Way to go!
    -Corbin
  12. maverick1970
    maverick1970 MCG State Rep
    Missouri
    What a deal! Nice find
  13. Jamie Miles
    Alto, GA
    I've had a few
    I'll give you your money back! :D
  14. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Such a deal. I have zero 6 cyl. GT's in the registry
    Send me the info and I will add it.
    For those that have asked, I am attempting to prepare
    a form to fill out with the necessary info.
    For now do this:
    1)Name of owner
    2)City and State (add the address if you like)
    3)Contact e-mail and phone number are optional
    4)I need the VIN number-complete
    5)The info from the blue tag inside the drivers door jamb
    6) J-peg format pictures
  15. Craig Selvey
    The only things I would add to what Seth has listed is:
    7) If you have any of the original paperwork, like a build sheet or bill of sale....send in copies of that as well.
    8) If your Comet GT has a body buck tag on the radiator support...a copy of that as well
