I hate power steering
Discussion in 'Technical' started by demo913, Jun 7, 2011.
  1. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    I am tired of throwing money at my power steering. Not to mention I hate it. What do I need to convert to manual. I would like to do this this weekend. I just need a parts list for power to manual. I don't want to use the adapter if possible also.
    Thanks...
  2. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    You need the manual steering linkage and manual gear box with pitman arm. Just remove the steering pump, gear box, and steering linkage. Simple conversion. If you need any parts let me know.
  3. maverick75
    Center link, idler arm, pitman arm, tie rod inner and outer, the tie rod sleeves. I think that's pretty much it. You can keep your PS gear box.
    If you have disc brakes you will have to keep the outer tie rods that go to the spindles.
  4. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    mike75mav I do need the parts. PM me with info. So I thought I could just change the centerlink and pitman arm. I guess I will be changing it all then. I will be keeping my power steering box cause it is only 1 year old.
  5. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    No you want to keep the power steering gearbox!!! It has a better turning ratio then the manual gearbox has. You get a steering ram drag link adaptor (http://cgi.ebay.com/ebaymotors/New-...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories )
    remove the valve. Remove the pump.
    Or you can just look at this article in Hot Rod to see how its done, it will save you money, it makes it easy to put the PS back on if you feel the urge and you will have a better steering ratio.
    http://www.hotrod.com/techarticles/..._power_steering_to_manual_steering/index.html
  6. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    I was thinking it would be better to go the route without the adapter. Never had luck withe easy way.
  7. mike75mav
    mike75mav Member
    Bremerton, WA
    You need to change everything from tie rod to tie rod. You can not use the power steering pitman arm because, for the angle difference. The power steering gear box does have a different and you maybe moving the steering wheel to much. You will be able to feel the road a lot better.
  8. mike75mav
    mike75mav Member
    Bremerton, WA
    One other thing. You don't need the power steering pump its extra weight and you can't hook it up.
  9. maverick75
    The adapter is just a band aid fix.....swapping to the linkage is the right way to go.
    And you can probably get the parts cheaper than buying the actual adapter.
    I've bought stuff from Mike before, great seller!
  10. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    I thought the tie rods and idler arm were the same for power or manual. Am I wrong?
  11. mav76302
    mav76302 Member
    Mesquite, Tx
    1976 Maverick Stallion
    possibly the idler may be different I ran into that as well on my swap.
  12. darren
    BIt of advice for after the swap. If you keep the power box or go to the manual box you may have a slight issue with Caster. Without the assist you may find you need to adjust the caster to make it a bit more friendly at slow speeds. Keep your hands on the steering wheel not in it for the first drive.
  13. injectedmav
    injectedmav Member
    Georgia
    X2
    toe is slightly different too. I tried to just swap once without altering the alignment angles, it wasn't pleasant.:Handshake
  14. demo913
    demo913 Member
    Charlotte, NC
    75 maverick 351w
    I plan on getting a good alignment when done for sure.
  15. 71gold
    these look pretty nice...
    this one i got from...Mustang Unlimited...my opinion was junk...:yup:
