So yea the front end of my 75 mav is higher then the back and i honestly dont like it. is there a way i can lower the front so the car can be evenly parallel to the ground?
Replace/re-arch the rear springs or cut a half a coil at a time out of the front till you get the stance you want.Then get the front end re-aligned.Good luck.
...as above...check the rear springs. they are the #1 reason for what you are seeing. good luck... ...Frank...
