i bought a tranny cooler
Discussion in 'Technical' started by stmanser, Jun 27, 2005.
  1. stmanser
    Davenport, Iowa
    which line do i use for the tranny cooler...
    c-4 tranny... is it the drivers side or the passenger side that i connect to...
    i used the touch method..but both lines were hot.... couldnt tell which line was hotter than the other..
    so if anyone has a tranny cooler on that works properly..please tell me the side to connect the tranny coller to...i am using it in conjunction with the radiator cooler
    thanks
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    If you bought a large enough cooler bypass the radiator cooler completely
  3. MiteeMaverick
    MiteeMaverick Senior Member
    Jonesboro, AR
    1987 Mustang GT Convertible
    Its the passenger side line on the bottom of the radiator that is the return, thats the one to connect it to. With it in line with the one in your radiator it will drop the temp about 70 degrees or more.
  4. stmanser
    Davenport, Iowa
    so i should have the line come out of the radiator on the pass side...go to the cooler...then come out of the cooler and go to the line on the pass side
    cool
    thanks.
    yeah i am hoping for some cooler temps
    it isnt large enough to bypass....that one was 80 bucks...the one i got is roughly....12X8 i think,.,,maybe a little bigger
  5. MiteeMaverick
    Jonesboro, AR
    correctamondo!!
  6. ShadowMaster
    ShadowMaster The Bad Guy
    The ShadowLands
    1969 1/2 Maverick
    Depends on what style cooler you bought. I have the B & M Supercooler (#70266) on my '98 GT. It is 8" x 11". It is a stacked plate design...not the tube/fin style. I bypassed the radiator completely and I drive the car every day and race it in FFW Mod Motor class. Never had a problem.
  7. stmanser
    Davenport, Iowa
    cool...i figured it better to have too much cooling than not enough....
  8. Jamie Miles
    Alto, GA
    I've had a few
    Trans cooler is the next thing I am going to do. (y)
