howling
Discussion in 'Technical' started by mitchwchristens, Mar 21, 2012.
  1. mitchwchristens
    mitchwchristens Member
    cedar rapids iowa
    1975 maverick
    we just installed new frame rails,springs 8 inch 380 posi,new brake shoes and all hardware including wheel cylinders,shocks on and on. for some reason on the test drive tonite we get a howl at about 45-50 mph. any ideas? sounds like it could be coming from rear of car. we installed new glass pacs and the need turn downs on them because the point at the rearend housing. any chance this is from the heat of the exaust thinning the rear end fluid? just a guess. i filled the rear end up to the plug hole ,is it possible it will need more? any thoughts would be valuable. Thanks.
  2. 71gold
  3. Bryant
    an improperly gear set will howl. in my experience when you get a howl on at those speeds its a poorly made gear set and there is nothing you can do to get rid of it. these days with all manufacturing being sent over seas its become impossible to guarantee that we will be able to get a good quiet gear set
    while doing the brake in is highly recommend it will not change the noise. you can not drive the noise out of the gear set
  4. injectedmav
    injectedmav Member
    Georgia
    X2, mine howls as well, the manufacturer told me I'd have to live with it and the setup is perfect.:cussing:
  5. MaverickLVR
    MaverickLVR takes longer then you think...
    Grand Rapids, Michigan
    1976 Maverick Stallion, 1967 Olds Delmont convertible, 1999 Harley FatBoy
    did you change the u-joints? those will howl....
