How to remove the seats?
Discussion in 'Technical' started by jcov14, May 21, 2016.
  1. jcov14
    jcov14 Member
    Fayetteville ,georgia United states
    1973 ford mavrick
    Trying to remove the seats in my 73 mavric but there are these huge circular bolts with a star shaped tread holding it in place. What tool should i use to remove it?
  2. Craig Selvey
    Those sound like your seat belt bolts.
    71gold likes this.
  3. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    That is a torx bolt. Go to any auto parts store they will have what you need, if not harbor freight will have it.
  4. 71gold
    got a pic?
  5. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    Or any ACE hardware.
  6. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    No special tools are required to remove the seats. Just use a 7/16" deep-well socket and a ratchet.
    The seat track studs go through the floor pan. Remove the nuts underneath the car.
  7. 71gold
    if they are stock seats and someone hasn't changed the bolts...:bouncy:
  8. jcov14
    jcov14 Member
    1973 ford mavrick
    thanks guys sorry for the late reply
  9. SlightlyRedneck
    SlightlyRedneck Member
    Fort Riley
    1974 comet
    I got my front seats out. Is it the same for the back seats?
  10. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Back seats are totally different. Push the bottom part of the back seat towards the rear of the car and simultaneously lift up as it is not bolted to anything...it just clips in. Once you remove the bottom section there are two bolts at the bottom of the back seat...one on each side. Remove those with the appropriate wrench and then lift the back portion slightly upwards and it should come out.
  11. SlightlyRedneck
    Fort Riley
    1974 comet
    Ahh thank you so much got it.
