how important is crank case ventilation
Discussion in 'Technical' started by Wesley, Sep 28, 2010.
  1. Wesley
    Wesley Member
    brighton colorado
    1973 maverick all stock 302 with a c4 tranny
    hey guys my car has no form of crankcase ventilation and i was wondering how much of a difference it would make hp wise? i dont care about smog etc.
  2. rthomas771
    Very important...without it you will have oil leaking at the gaskets and eventually ruin the engine.
  3. PaulS
    If the car you are talking about is the 73 Maverick and it was made in the USA it should be fitted with a PCV system which is the crankcase ventilation. If it has been removed then it should be put back on. The PCV system helps the rings to seal and minimizes wear by removing fuel and water vapor from the crankcase. Even professional drag racers use crankcase evacuation systems to help keep their engines sealing.
  4. Wesley
    Wesley Member
    brighton colorado
    dam that explains a few things!!!!! okay i have an edelbrock 1406 carb on it is the pcv the small tube on the front of the carb between the 2 adjusting screws?
  5. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Never seen a gasoline engine without crankcase ventilation. The rings don't make a perfect seal with the cylinders so some gases (blowby) enter the crankcase. Its gonna come out somewhere.
  6. FordsForever
    FordsForever Member
    santa clara, ca
    74 mav
    The pcv is there to recycle crankase vapors. And to keep internal pressure from blowing out seals and gaskets. Not to lube the rings.
    Brillance everywhere. :rofl2:
    RS
  7. maverick75
    When i was down in mexican i took some engines apart that didnt have pvc systems and they had excessive sludge buildup. All those vapors not having a place to escape wrecked havok on them. Im not going to run a PVC system on my engine but instead a breater can system. But Unless your building a high HP engine stick with the PVC system.
  8. Wesley
    Wesley Member
    brighton colorado
    stupid question......can anyone explain how to install a pcv system with my edelbrock carb...................
  9. FishnRace
    FishnRace Jamie
    Solomon's Island, Maryland
    '72 2dr 351
    Was there a mention of lubing rings? :hmmm:
  10. Mavman72
    Do you have valve covers with a hole on each one??? gotta have that just to get started. Then you will need a PCV valve, a proper length of rubber/neoprene hose to reach the valve cover you install the valve on. A grommet to fit it into and attach it to the cover and a open breather for the other cover and a grommet to mount it as well.(this will go on the cover you pour oil into the engine through) Connect the hose to the fitting on your carb that you asked about initially, connect the other end to the mounted PCV valve and bobs your uncle!!! Good luck!
  11. Wesley
    Wesley Member
    brighton colorado
    thank you headed to get some hosing and find new vlve cover inserts right now. so basically one has a air filter the other has the hose going into the valve cover
  12. Bryant
    Whos Bob?:hmmm:;)
  13. Mavman72
    It means "In like flint" :D
  14. Bryant
    i dont know flint either.:huh:;)
  15. Mavman72
    James Coburn...Sort of a spoof of James bond...Men from U.N.C.L.E.
