How do I post a picture
Discussion in 'Site News, Feedback, Forum Suggestions and Help' started by Always8, Apr 11, 2004.
  1. Always8
    Always8 New Member
    California
    Maverick
    Can some one explain to me in a easy way.
    Please and thanks
    Stephanie
  2. 71gold
    a-8, i go to, post reply, enter text. at the bottom go to browse. click on it and it takes you to your pics. click on the pic.and enter. then click submit reply. that works for me (most times). make sure the pic. size is less than 90kbs. hope this helps. most of mine are 30kbs.or less...frank...:bananaman :bananaman
  3. Always8
    Always8 New Member
    California
    Maverick
    Thanks
    I have one more question... How do I make my picture or the file smaller??
    On the attach file thing it says the max size is 102. but my pictures are 421. Can you help..??
    Or way that you explained posting pictures is really easy
    Thanks
    Stephanie
  4. Stefan
    Montreal, QC
  5. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    How To Add Pictures
    To add pics: as of June 16th, 2004
    A) Click on "MANAGE ATTACHMENTS" when creating a post.
    B) Click on "BROWSE".
    C) Locate the file (on your computer) that you want to upload.
    D) Enter "OPEN" (I know - it doesn't make sense - we don't want to 'Open' the file but
    that's the way Microsoft allows it).
    E) Click on "UPLOAD".
    F) If you have only one picture to upload, click on "CLOSE THIS WINDOW".
    F1) If file is too big, which is common, you must resize the picture using a picture
    editing software to downsize it to 100,000 KB (100KB).
    F2) Most folk have MS PAINT that came with their Windows (most versions).
    F2a) Using the Microsoft Explore option, locate the file and right click on the
    picture then click on "Edit".
    F2b) The file should then open up for editing.
    F2c) Click on "Image" then "attributes" to see the file size. "Size on disk" will
    indicate the file size. Using that information, guess at how much you need
    to reduce it's size by.
    F2d) Click on "Image" then "Stretch / Skew". There you will be given the option
    on how much to reduce (or enlarge) the picture by percentage,
    horizontally and vertically. Typically, 50% on each will reduce the picture
    size enough (in general).
    F2e) At the Tools Menu, click on "File", then "Save". Accept the original name or
    rename it (I normally rename it so that I don't screw up the original). You
    are now working on the file name that you chose.
    F2f) AGAIN, click on "Image" and "Attributes". Your file size should be a lot less
    than the original. If the file size is now under 100KB, proceed. Otherwise,
    continue to reduce it in size until you have it under 100KB.
    F2g) Go back to your post and start at step "A" again.
    G) If you have multiple pictures to upload, click on "BROWSE" and "Upload" again.
    H) AFTER you have finished uploading the pictures that you want to post, click on
    "Close This Window".
    I) After being returned back to your original message, click on "Preview This Post",
    scroll down to "Additional Options". You should be able to see that your files are
    attached under "Attache Files" heading.
    I don't claim this information to be true on everyone's PC, but it at least should give you an idea on the required steps.
    Gluck,
    Rick
  6. papawdarrell
    papawdarrell papawdarrell
    Arkansas
    1973 Maverick
    THANKS RICK, IT'S NOT SO MUCH AS NOOB, IT'S MORE LIKE COMPUTER ILLITERACY(?) I GAVE IT A SHOT, LETS SEE WHAT HAPPENS.:confused:
  7. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Hey ... that car looks familiar!
  8. scooper77515
  9. scooper77515
    It worked!!! Thanks for the help.
  10. papawdarrell
    Arkansas
    1973 Maverick
    I can't tell for sure, but the hubcaps on yours looks like the ones that were on mine when I bought it. The cars are/were pretty close. There used to be one around here that had a vinyl top, that was the only difference. The way he drove and took care of his, I doubt the car is still around.:mad:
