"hot air"
Discussion in 'General Maverick/Comet' started by JAYSMAV, Mar 13, 2011.
  1. JAYSMAV
    JAYSMAV Member
    Ohio
    '73 Comet 302 LDO auto, '70 Maverick I6
    Does someone know if the 1970's Mavericks came with a fan shroud? I took the shroud off my '73 Comet but it's for a V8. I tried to swap the radiators also. Still though, the engine in the mav is a stright 6. Nothing matches up. :huh:
  2. smegnl
    Wadsworth, Ohio
    1970 Grabber Clone
  3. JAYSMAV
    JAYSMAV Member
    Ohio
    So i'm guessing the '70's didnt have fan shrouds then? I want to try using some hard foam insulation & fiberglass and make my own. I saw somewhere, sometime, I think in a magazine, maybe on t.v. someone did that. lol. should be interesting seeing how I've never worked with fiberglass before. EVER.:rofl:
  4. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    One of the main things you need to know about working with Fiberglass is safety, safety, safety,... where some sort of filtered air mask, even the cheap throw aways would be better than nothing. You do NOT want to breath that **** into your lungs. Also cover all exposed skin.
    Other than that it is just making a mold of what you want the thing to look like, cover the mold with some form of release agent so the fiberglass doesnt stick to the mold and lay on the a layer of the fiber cloth and paint it with the resin, another layer of clothe, another layer of resin until you ge the thickness/strength you want/need... It's not really hard to make something out of fiberglass if you are a little creative and can spend the time and be patient.
  5. sgaugeguy
    sgaugeguy Bob Kraus
    WILLIAMSTOWN NJ
    I would find the part number for your radiator either the OE number or the aftermarket number and then see if it is the same as any Mustang. Then look for a shroud for that Mustang thats applicable. There seems to be quite a few Mustang shrouds out available ...
  6. JAYSMAV
    JAYSMAV Member
    Ohio
    Thanks for the heads up about the fiberglass! I didnt know it was so hazardous to work with. Also, I'll check those numbers out. Thanks again.
  7. dunno
    dunno Member
    east texas
    70 maverick
    My 70 does have a fan shroud. And it is indeed oem.
  8. whitey68
    whitey68 Member
    springfield illinois
    71 comet gt 65xxx orig miles .. 69 mercury marquis 2dr hard top land yaught, 62xxx orig 2 owner 429 4bbl 2000 heritage softail
    i need a v8 shroud for my 71 comet gt if anyone is looking to sell one
