hooker 6901's hit the chassis on my '71
Discussion in 'Technical' started by xpsnake, Aug 21, 2006.
  1. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    Did not notice this until a few days after the engine install. I get a nasty vibration when I'm coming out of first gear and I finally tracked it down. The hooker 6901's I bought rub against the area just ahead of the torque box on the driver's side of the car. It's just close enough to hit when the headers resonate. I didn't see anyone else having this problem and I wonder if there's any solution, or problem with leaving it as is.
  2. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    why do these headers fit differntly on every single car?
  3. 1971CometGT
    1971CometGT Member
    McDonough,GA
    shoulda bought Heddman's
  4. scooper77515
    Don't buy Hedmans, just use a BFH on them. No more rub... :D
    Honestly, I think that the unibody is warping differently on each of our cars, and causing the headers to "fit" differently.
  5. 69 ina 1/2
    69 ina 1/2 Fox body nut!!!
    Smog Bernardino, Ca.
    This is most likely what is causing all these problems. Here is a few more things that affect header fit...
    worn out motor mounts
    fender benders
    sagging shock towers
    header pulled a little when welded together (its a long shot, but it can happen).
    Scoop has the best solution for all of this, give it a clearance bap with a hammer:D . Its not uncommon to have to do this, especially since the vehicle is older and that header was probably designed when the car was rather new.
  6. xpsnake
    xpsnake Bruce
    I'm going to let it rub for now, I've got lots of other little dings in my $$JETHOT$$ coating already anyways. In order to hammer on it, I would need to disconnect the exhaust, unbolt the header, lift the motor, drop it, and then reverse.
  7. blugene
    My blackjunks rubbed also. I used a big Snap On pry bar (and a hammar) and just bent it in a little. It would have rubbed a hole eventually otherwise.
  8. 1971CometGT
    1971CometGT Member
    McDonough,GA
    NO rub at all with Heddman's :)
  9. scooper77515
    on your car, but they had fitment issues with others'...
    There is no single one model that has fit every car without some rubbing issues.
  10. newtoford
    newtoford Member
    New Castle Delaware
    flowtechs went on all my gm's no problem a.k.a. no hammer needed. They were all pretty cheep too.
  11. mean_maverick
    Someone Else Around Here Had A Set Of Flowtech's And Mentioned They Fit Well. I've Got The Hooker 6901's On Mine As Well But Mine Havent Rubbed Anything That I Know Of.... Yet....
  12. scooper77515
    My 6901s just barely touch the fender on the passenger side, then there is that spot where they would hit the steering doohicky if you don't buy the power steering drop bracket. But, there is plenty of clearance on the other side, making me think the engine isn't perfectly centered, or my frame has a little twist. I have since determined that I do, in fact, have some semi-serious twist, and will have to have the frame alligned before I put in sub frame connectors and roll bars to hold it all straight.
  13. Mavaholic
    First I ever heard of 6901s hitting anything.
  14. 69 ina 1/2
    The 6901's and flowtechs are exactly the same. Flowtech knocked them off:D . When your dealing with a car as old as ours each car will have a slightly different clearance problem. If the headers all rubed in the same place...then the header was designed wrong, very doubtfull. JMHO;) .
  15. Dave B
    I had Headmans on my white 74 for years, never had any problems, but the car is pretty solid, and had never been hit. I had them on my red 74 before that, and they seemed alot closer to the bottom curve in the firewall area, but that car was wrecked pretty good at one time in it's life. Same motor in both cars, same motor mounts and everything.
