holes-be-gone
Discussion in 'Cosmetic' started by Racer_X, Apr 29, 2009.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    i have some small holes in the top of my hood where my scoop used to be and now i wish to fill them in. should i use bondo? is there anything else that works better? i dont want the patchwork to show once the hood is re-painted
  2. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    bondo will eventually break loose. you would be 100% better off if you find someone to weld them for you
  3. Jeff S
    Jeff S Member
    NoVA
    none
    Bondo should work, make sure you use a large sanding block lightly when it dries and not hand-powered sandpaper, otherwise the holes will become slightly visible when painted.
    A type of fiberglass resin or something stronger would be better though
    My opinion on what to do anyways.
    EDIT:Welding is the best answer, and I completely overlooked that option...lol
  4. Racer_X
    North Carolina
    i thought about jb weld :huh:
  5. Jeff S
    Jeff S Member
    NoVA
    none
    Ive known people to do that with no issues, and some of those people are still driving their car today with nothing falling out, just make sure under-hood it has a good jb weld base to hold it from falling over time.
  6. Craig Selvey
    Welding is your ONLY option in my opinion.
  7. Jeff S
    Jeff S Member
    NoVA
    none
    Some people dont have access to a welder, and have to resort to less desirable measures...like me, I dont have access to a welder,.:p
    But I do agree that welding is by far the best option.
  8. 1973Maverick357
    Cookeville TN
    How much is a good stick welder cause i need one
  9. Craig Selvey
    Poster originally posted: i dont want the patchwork to show once the hood is re-painted
    In my opinion....welding is the ONLY option. If you don't have a welder...pay somebody to weld it for you.
  10. Dave B
    Patching a hole in a hood with just bondo will not work. You'd be better of using fiberglass mat on the inside, to give whatever you fill the holes with, something to hold it in place. Take your hood to a body shop, they'll weld it up cheap.
  11. Racer_X
    North Carolina
    thanks, i decided to cut the hood and replace my scoop so it will be functional.
  12. brainsboy
    brainsboy Member
    Tampa
    I have to agree!! Welding is the only option. Im sure someone has a buddy that has done it and it has lasted 15 years that way, but yours wont be the one. I have done alot of paint jobs over twice because of taking short cuts like this.
    Also just to post because I saw something about a stick welder, you cant fix holes in a hood with a stick welder.
  13. Racer_X
    North Carolina
    my pops has a welder, its the kind that treads a metal wire through the machine and out through a little gun, not sure if that will work any better:huh:
    i think its called a wire welder duno for sure though:huh:
  14. maverick1970
    maverick1970 MCG State Rep
    Missouri
    That is a MIG welder some call them wire feed welders
  15. Racer_X
    North Carolina
    would it do as good a job as the stick welder? if not i can go to the local mustang shop and have it done, the guy there should have a stick welder.
