Hoist
Discussion in 'General Maverick/Comet' started by lika, Jun 22, 2009.
  1. lika
    lika Señor Comet
    IA
    comet 71
    Which one is the best hoist to use to lift a 302 engine and a c4 transmission
    1-ton
    or
    2- ton
    thanks
  2. JHodges
    JHodges thumper
    Dora Alabama
    I have a 2 ton and had lifted b ig blocks with it
  3. don graham
    1 ton should be fine. I have one that is a 2 ton when it's boom is pushed all the way in, but you can't get it far enough under the car. So, I use it all the way out where it's 1 ton and i've never had any problems with it. :)
  4. lika
    lika Señor Comet
    IA
    comet 71
  5. Bryant
    the 2 ton should be more stable and dependable than the 1 ton. now to keep perspective, a 302 should weight around 475 add a c4 trans that weighs around 125 lbs and your over a 1/4 ton (500 lbs) in weight. the 1 ton with its boom fully extened will be byond max capacity. you will need the boom to be extended to clear the front bumper on our cars.
  6. PaulS
    The best hoist is a 5 ton travelling hoist but the smallest "cherry picker that I would use would be a 2 ton.
    I use a 3 ton travelling hoist in my garage - but it only travels along one rail - no room for the full travelling hoist.
  7. madman21
    madman21 Beer is good
    Albuquerque, NM
    1976 2dr Mav 410ci
    +1
    get the two ton.
  8. sierra grabber
    sierra grabber Certifiable
    northern nevada
    i have the two ton from harbor, bought it because it was only $40 more than the cheapest rental i could find around here. thought i would only use it once and then leave in storage. ended up using it three more times on different projects and it is good i got the two because you can extend it out to only have a one ton capacity for a higher lift (engine out of a boat still on trailer, lifted pickup engine)
  9. lika
    lika Señor Comet
    IA
    comet 71
    thank you so much:tiphat:
    i have decided to buy (2 ton) (y)
