hit curb
Discussion in 'Technical' started by built1967, Dec 28, 2006.
  1. built1967
    built1967 New Member
    littleton co.
    1974 2door
    daughter hit curb with 1974 maverick and buckled wheel under car, It broke a weld on shock tower and almost poped out upper ball joint, i welded shock tower and now it appears as if the front sway bar is bent, question is after replacing sway bar will there be more bent stuff? all else apears ok Larry in colorado
    P.S. does anybody have a sway bar?
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    check tie rod ends...control arms...front bar thingamajjer( torison bar? kinda points towards the front , cant remember what its called:( )
  3. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    Your working on the car in the snow?
  4. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    STRUT ROD:D
  5. Craig Selvey
    Strut rods can be straightened if thy are not bent real bad. If is bent real bad.....I have one I can sell you. Email me directly if interested.
  6. eddie1975
    Martinsburg, WV
    sold
    DOH thats right :D had a brain fart
  7. stmanser
    Davenport, Iowa
    i was wondering what that smell was.. lol
    you can fix pretty much everything. and you can find most parts on this forum.. welcome aboard and good luck fixing it..
    glad your daughter is ok...
  8. awannabegrabber
    awannabegrabber Always Learning
    Wichita, Kansas
    1976 Maverick with a trim package
    how hard do you have to hit a curb to do that much damage
  9. built1967
    littleton co.
    1974 2door
    If any one has the front sway bar that they would like to sell email me direct at grdnscen@aol.com and thanks for all the ifo, cor was only going maybe 20 or 25 miles an hour so did not take much.
  10. Craig Selvey
    Email sent.
  11. Scootermagoo
    Scootermagoo Member
    Portland Oregon
    1973 Ford Maverick Grabber ginger & white factory 302 c-4 car LDO package
    (best military sergant voice) seems like a common occurance.. don't let it happen again or I'll have you benchpressing 9inch chunks for the next month MISTER!!!! do ! make myself understood.
