High Speed Vibration
Discussion in 'Technical' started by Liam McDermott, Sep 11, 2010.
  1. Liam McDermott
    Liam McDermott Member
    Muskoka, Ontario, Canada
    '76 250 4-door Mav
    Hello all,
    My mav is currently awaiting a carb rebuild of the stock 1 barrel for the 250 engine. Ever since I bought the car, at mile 23,000 or so, I haven't taken it very far over 60, due to a very uncomfortable vibration at high speed. The engine sounds strained when this vibration is occurring. Under its first owner's care, the car sat for extended periods, causing the seals in the carb to become less than optimal. My question is this: when the carb is rebuilt, will the engine run smoother, at a lower rpm, at 65+ speeds?
    Sorry if that sounded silly,
    Liam.
  2. rthomas771
    The carburator has nothing to do with vibration. It does have something to do with stumbling which will make the car shake.
  3. Bryant
    odds are the vibration is from the drive shaft. there are three things that can be causing it.
    1 bad u joints. pull the drive shaft out and rotate each u joint. they should turn smoothly and easly.
    2 bad operating angles on the u joints. this is usally caused by the motor mounts or transmission mount colapsing causing the angle the u joints operate under to co change. they have to stay if phase with each other to operate smoothly. care fully inspect the mounts for cracking or oil soaking.
    3 wrong size u joint caps in the diff yoke. check to make sure that the u joint cap fits snugly in the yoke.
    if you put the motor into nutrual when the vibration is happeing and it goes away then its probly engine related. if it doesnt go away its probly one of the above problems.
  4. MikeG747
    MikeG747 Member
    Arkansas
    I had a bad vibration at highway speeds and it turned out to be a bad transmission mount. Good luck. (y)
  5. Liam McDermott
    '76 250 4-door Mav
    Thank you very much for the advice. It may be a sputter that is causing shaking and I'm just confusing the two. I will check over the other potential problem points just to be sure.
    Thanks again,
    Liam.
  6. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    Have you been underneath the car and taken a good look around? If the car has sat for long periods of time maybe it is something as simple as a big Dirt Dobbers nest on the drive shaft or behind one of the wheels on the brake drum. If the same tires are on the car and they are old they may have flat spots on them from sitting.
    I remember when I was in the Air Force we had an old International Power-Line truck. It didn't get driven unless we had to set some new power line poles. Most of the base was underground stuff so it didn't get used much. When it would get driven it would beat you half to death with all the flat spots on the tires.. lol
    clint
  7. baddad457
    :16suspect I hope our Nuclear arsenal is better cared for than that truck was. :huh:
  8. idrivemav
    idrivemav Member
    texas
    1975 maverick
    when my car sat for a while when i was building the engine the car sat for over a year and when i got it running again the first time i drove it over 50 it shook like a dog ****ting peach seeds it turns out all 4 wheels were filled with snails and was making the wheels out of balance it was kinda weird ive never seen that b4 ive seen dirt dobbers but never snails
  9. Liam McDermott
    '76 250 4-door Mav
    The tires are fairly new radials, never having sat too long. I notice it drives really smooth until I get to around 65, when the engine is working too hard.
