Heres why my 302 was siezed up
Discussion in 'Technical' started by newtoford, Aug 15, 2008.
  1. newtoford
    newtoford Member
    New Castle Delaware
    if you were paying attention to my other thread...
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Glad it was just the starter.
  3. newtoford
    newtoford Member
    New Castle Delaware
    yahhhhh, very happy about that :)
  4. PaulS
    Now you have to figure out what caused it... is it a manual or auto transmission?
    The starters for the autos are a different length than the starters for the manual transmissions.
  5. Dave B
    Wow, hows the flywheel??
  6. Mavaholic
  7. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I had a strong suspicion that would be the culprit. Guessing the flywheel came out okay? The motor obviously came to an abrupt halt when that happened.
    Dan
  8. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    That gotta hurt. I was thinking same thing, wrong starter.
  9. newtoford
    newtoford Member
    New Castle Delaware
    flywheel's fine. i spun it around, all the teeth look good. i got a cheap pepboys starter now. it is specificaly for an auto but i'll post some pics up just so you guys can double check for me.
  10. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    Does the starter match your flywheel? I thought you went with a roller motor and that uses a different tooth flywheel....:burnout:
  11. newtoford
    newtoford Member
    New Castle Delaware
    its a roller motor but i still had to get a correctly balenced 157T flywheel to use a sbf C4. the block's a '91, the C4 is original to the car with the 250/SB v8 bell bousing
  12. rthomas771
    Do you have a block plate between the engine and transmission?
  13. Craig Selvey
    So what do I win? :D
  14. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Looks like the thrust washer somehow crawled into the pinion.....
  15. Dan Starnes
    West Central IL
    Jeff asks a critical question.
    Dan
