help!!!
Discussion in 'General Maverick/Comet' started by mick3ysix, Oct 13, 2010.
  1. mick3ysix
    mick3ysix New Member
    Los Angeles, CA
    73 ford maverick
    im an ameteur mechanic im still in the process of learning the tricks of the trade and i ran into a problem, see i believe my transmition is shot, i put my mav in drive and it dosent go anywhere! this applies to drive, 2, 1. however myreverse park and neutral work just fine, do i need a transmition rebuild? and how much will that range me?
  2. rthomas771
    Your transmission need rebuild. Cost varies location to location.
  3. Bryant
    make sure it has the right amount of trans fluid in it. you need to check it with the motor idling in park on a level surface.
