Help
Discussion in 'General Maverick/Comet' started by Ken Thompson, May 10, 2006.
  1. Ken Thompson
    Ken Thompson Member
    Kennesaw,GA
    I have a 76 Maverick, 250 and C4 auto. The problem is confusing to me....
    First off, I have tuned the engine, plugs, wires, cap, rotor, fuel pump, filter, air filter, and cleaned out the gas tank and added a fuel filter to the fuel sending unit.
    Now my problem is when driving down the road, about 30 minutes, the engines starts sputtering and wants to die. Then after loosing a few mile per hour the engine eases back up to speed. Then it runs great again for about another 15 minutes and then it acts up again.
    The electronic module is a Duraspark and I have no idea how old the coil is. Please help I really need to get this car going.
    Thanks,
    Ken
  2. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    When you say that you "added" a filter to the sending unit, what does that mean?
  3. Ken Thompson
    Ken Thompson Member
    Kennesaw,GA
    Hi Tom,
    It's the screen filter that goes on the fuel sending unit. Mustang Unlimited part number: F2253. The paper filter that was on the fuel pickup was in pieces.
    Mustang Unlimited suggested that the Electronic Module is the culprit.
    Ken
  4. Ken Thompson
    Ken Thompson Member
    Kennesaw,GA
    Problem resolved, it was the duraspark module. AutoZone tested the my old module and found it has a leakage.:bananaman So I bought a new module, p/n F102 and a coil C832G.
    Ken :drink:
  5. Tom Laskowski
    Bay Area,California
    Glad it turned out OK, so you did not add a filter you just replaced the pick up screen, had me thinking about that one.
  6. maverick75
    hey ken did you use a mustang sending unit on your 76 tank because i have a 76 tank but with not working sender and i dont trust AK enough to order one from them and i've seen the mustang sending units for as cheap as $20
    if so which year mustang?
    thanks
  7. Ken Thompson
    Ken Thompson Member
    Kennesaw,GA
    You are correct, I added the pick up screen. I have a new filter to add to the carb and already have a new filter just before the pump.
    Ken
  8. Ken Thompson
    Ken Thompson Member
    Kennesaw,GA
    No I didn't, the pickup tube for the mustang is about 1 1/2 inch too short. We went through about 3 sending units and 5 tanks. Mavericks are a X@@X car. I think the sending unit is spot welded on the pickup tube. That said, you might be able to break the spot weld and exchange the sending units.
    There was nothing wrong with my sending unit.
    Ken
  9. maverick75
    thanks for the info
