HELP, HELP-Vacuum modulator dual ports!
Discussion in 'Transmissions' started by falconscjman, Sep 12, 2011.
  1. falconscjman
    falconscjman Member
    phoenx, az
    74 2dr blue 250 6 cyl
    We have a 74 Mav 250 car w/a C4 trans. The modulator has 2 ports one I know goes to the intake for a vacuum source like any car, but where does this small port go to??? I've been all thru the 74 shop manual & there is nothing about this anywhere, also the internet is no help either. Can I just stick a regular 1 port modulator in there since we're getting rid of all the 74 stock emission stuff anyway????
  2. miguel
    miguel Member
    GARDENA ,CALIFORNIA
    1970 maverick
    I will find out for you if I can my 1970 maverick with the 250 should have that same ports,I'll check ina lil ,I got sick by over eatin nd now I'm throwin up,no I don't have eatin problems I just had too much indica(cannabis)
  3. PaulS
    The rear (larger) port is the only one that you need. It connects directly to manifold vacuum. You can also replace the modulator with a green stripe modulator with only one port.
    The secondary port was originally connected to the EGR vacuum to make the shift softer - the stock shift is soft enough.
