Help!!!! fallen windows
Discussion in 'Technical' started by Alexander, May 30, 2014.
  1. Alexander
    Alexander Member
    Tucson
    1971 Ford Maverick Sedan
    The driver and passenger side glass have fallen down.:cry: The glass seems to be held by some plastic inserts.:huh: . Do you guys know where I can get new one's? I'm only sixteen and don't go alot of money. Thanks.(y)
  2. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    You can buy new reproduction at Restoration Parts Source :
    http://restorationpartssource.com/store/product160105.html
  3. YellowStangDuan
    YellowStangDuan Member
    Arlington, Texas
    71 Grabber
    Thanks! I need those too and couldn't find any.
  4. rayzorsharp
    Did you check in the bottom of the doors? I rarely see these fasteners break but they don't usually just fall out either. The fasteners are two-piece. If you do have them you simply put the big piece in first making sure the glass is flush with the track and push the pin in until it's flush with the big part of the fastener. It should fit pretty tight so you will likely have to tap it in with something. If you don't have both retainers (4 pieces total for each window) then there's no need to mess with it until you get the correct parts. Just see what you do have and if you will pm me I'll see what I can do about getting you some. And I guarantee you won't beat my price unless you find somebody that will pay you to take them. :)
  5. YellowStangDuan
    Arlington, Texas
    71 Grabber
    Mine is broke, I had it rigged with some other hardware. Time to fix it right.
  6. Alexander
    Alexander Member
    Tucson
    Thanks for the help guys
