Help dashlights don't turn on
Discussion in 'Technical' started by anthonyv90, Nov 13, 2010.
  1. anthonyv90
    anthonyv90 Member
    South Los Angeles,California
    71 maverick,69 429 thunder jet T-Bird.
    I recently put a stereo in my car n then my dash lights won't turn on changed every single fuse but they still dnt turn on can anyone help..
    Or should I jus go with the process of elimination.?
    Than in advance
  2. anthonyv90
    anthonyv90 Member
    Can anyone help me.?
  3. maverick75
    Where did you tap in for power for the radio? Do the lights work when the radio is off?
  4. anthonyv90
    anthonyv90 Member
    It was from where the other radio was connected a red cable..
    Everything works except for the gauge clusters..
    And I think the thing that marks the gear the trannys in..
  5. anthonyv90
    anthonyv90 Member
  6. maverick75
    So you tapped into the one that lights up the gear display? If so that should only be on when your lights are on. Radios need switched power. And constant 12V if it has a memory function.
  7. anthonyv90
    anthonyv90 Member
    The radio turns on but the clusters dnt..
    But the radio loses memory every once in a while..
    The other stock radio was connected to the same spot and the clusters would work..
    What can it be ):
  8. maverick75
    Where did you splice in for the memory wire? The stock one didnt have that feature. My guess is that you might have tapped into the wire that supplies power for the backlights on the cluster.
  9. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Dumb question I know, but have you rotated the light switch knob? All the way one way it cuts off the cluster lights, all the way the other way it turns on the dome light. Could just be the rheostat that dims the lights has a little corrosion on it. Turn the knob back and forth a few times, that should clean it enough to make it work....
  10. anthonyv90
    anthonyv90 Member
    @Maverick75:it's connected to the same red cable..
    @Ford84stepside:Yea I turned the knob back n forth n the dome light works..
    But I'll try again it..
    The red hi beam indicator, turn signals everything Works but the cluster lights..
  11. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Disconnect the power from the new stereo and see if the lights work.
  12. anthonyv90
    anthonyv90 Member
    @maverick1970 ok I will..
