Hello and I need some help
Discussion in 'New Members Forum' started by ArenD, Oct 10, 2004.
  1. ArenD
    ArenD New Member
    Hello I am 18 I have just started my commet project. Its a 66 and it has a blown 289. I, being pretty cheep, bought a trashed ford fairlane with a 289 that was running strong, I then rebuilt the fairlane 289 with some goodies (hopeing for 200 rear wheel HP). And while I was at it I had the commet transmission rebuilt at a shop (all OE parts), this all set me back about 2200 dollars, so now the problem... I put the 289 against the commet trans mission and it dose not bolt up.
    what can I do? I have the transmission from the fairlane but it has a dash shifter, and the commet has the floor, is it hard to convert the dash shifter to the floor style. both trannys are automatic.
  2. ArenD
    ArenD New Member
    yes Its comet not commet opps
  3. 71gold
    hi a.d.
    that '66 was before my time. maybe one (the one) of the old guys can help you, like "hawkco". it is 8:30 pm here so he is prob. in the bed. if he can get up, he will be up around 10:00 tomorrow...frank...:clap: :clap: :clap:
  4. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    Welcome to the board.
  5. Mavaholic
    I believe it was around 67 when Ford changed from a 5 bolt bellhousing to a 6 bolt. If the trans case is all on piece, about all you can do is have the parts switched to the transmission you need. If the bell part of the case is removable (I'm not an automatic guy so I dont know for sure) then you should be able to swap it out. I know a long time ago we used to pull transmissions without pulling the bell part. Or you could just get a 302 and put your new transmission on it.
  6. grabber37
    grabber37 Member
    New Mexico
    1971 Maverick Grabber
    Lets start with, is the Tranny out of the fairlane A C4 or a FMX? I think that the fairlane did not come with the C4. If the are both C4 tranny's the only thing that you will need to change from the colum shift fairlane C4 to the floor shifter comet C4 is the manual valve lever. Sounds harder than it really is.
  7. electronx
    electronx New Member
    southern california
    1975, In line 6 Cylinder, black, c-4 transmission
    I have a Maverick in pretty good Shape for free.
    Hi everyone,
    I have a Maverick `75 that I can't keep anymore. If anyone is interested send me an e-mail. I should also say that it is not running. It will need a rebuild of both the transmission and the engine. The body is in perfect shape.
    maverick35188@hotmail.com
  8. bmcdaniel
    Mid year 65 is when the blocks and bells changed from 5-bolt to 6-bolt.
  9. newtoford
    newtoford Member
    New Castle Delaware
    your working on a '66 comet? this forum is set up for the '71-'77 generation so you might have some trouble finding the best answers, but we're still happy to help :) as everyone else has said, you'll need a 5 bolt bell housing. i hear they are pretty hard to find. im sure there is an adaptor plate on the market if worse comes to worse and maybe an aftermarked shifter to solve your linkage problem.
  10. Craig Selvey
    electronx revived a 2 year old post.
  11. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    1964 was the last year for the 5 bolt bell housings. Some of them blead over into the 64 1/2 mustangs but that is all. All 1965 small blocks were 6 bolt.
  12. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    dug this one from the grave:slap:
  13. ArenD
    ArenD New Member
    wow good thing I subseribed to this topic when I posted it years ago, but huh yeah its all fixed now I simply rebuilt the fairlane tranny and converted it to a floor shifter very simple to do... car runs great but is hidden away in a barn in CA were it can evade rust for a few more years untill I am on my feet and can restore it the way it should be done.
  14. newtoford
    newtoford Member
    New Castle Delaware
    i didnt even notice the date 10-10-'04 :rofl2: :huh:
  15. maverick75
    You've got mail.
