Heat/Choke Riser Tube
Discussion in 'General Maverick/Comet' started by Renton5, Nov 16, 2013.
  1. Renton5
    Renton5 Member
    Van Nuys, CA
    1971 Maverick, 200 engine, 2dr
    Hello, I have a '71 Maverick with a 200 engine. I've discovered that the heat/choke riser tube is broken about about an inch from the bottom, but it's still within the sleeve material. Will keeping it within the sleeve be enough to allow the manifold heat to rise up to the choke, or will I need to replace the entire tube? I could buy a length of steel tube and by using a bender, copy the bends in the tube and I can flare out the end for the nut, but I don't know how to make the manifold end small enough to fit into the hole.
    Any suggestions are welcomed!
    Thank you!
    Renton5
  2. Renton5
    Renton5 Member
    Van Nuys, CA
    I like that idea, thank you!
  3. royboy88
    royboy88 Member
    decatur il
    77 ford maverick, 69 ford custom 500, 94 ford explorer
    I used 1/4 inch brake line on mine
    littlekentucky likes this.
  4. Renton5
    Renton5 Member
    Van Nuys, CA
    Hi Royboy88,
    How did you make the end of the tube small enough to fit in the manifold?
  5. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    you also can use soft copper and drill the hole in manifold to fit your line size
  6. royboy88
    royboy88 Member
    decatur il
    I drilled the broken piece out and wedged it in
  7. Paul Masson
    1971 Grabber
    I believe these can be purchased via Mustang parts houses, and are $20 or less...
  8. Krazy Comet
    Whatever size the line is was the original size in the exhaust manifold, usually due to rust and remnants of the line, opening will be smaller than orig... I've bent new line and drilled the manifold back to same size without issue...
    A stick of new line should be just a few $$, I paid $2.65 last week for a 30" piece of 5/16", should be able to get 1/4" for even less...
