Healiner Help
Discussion in 'General Maverick/Comet' started by qkrthnu, Aug 22, 2009.
  1. qkrthnu
    qkrthnu Member
    Michigan
    1973 Comet GT
    OK everyones been a great help headliner bows are installed and headliner is held in place by clamps to hold in place while streaching. WHAT KIND OF GLUE IS BEST TO USE? is the question though :huh: so far it hasnt been that bad at all :) actually cant believe I was dreading it so badly
  2. Dave B
    I bought some glue from National Parts Depot, it's a contact cement. It's not like anything you'd find in a Home Depot, it worked awesome.
  3. rayzorsharp
    I normally use a 3M brand of glue for my headliners. I think it's called Super Trim Adhesive. Make sure it says "super" because there are two different ones. You spray both items to be glued, give a few seconds, touch it together a couple times and it's ready. It can easily be pulled loose and repositioned if needed...and you will need to. Should be able to pick it up at any paint supplier and some parts houses.
  4. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    x2.....I found this out when I was doing my interior :thumbs2:
