Headers WITH a column shift
Discussion in 'Technical' started by cmbtengnr, Jun 19, 2006.
  1. cmbtengnr
    cmbtengnr Member
    Atchison,KS
    Yellow '75 w/blk top
    okay I've seen alot of posts about headers and some threads people say they bolt right up and others say you gotta switch to floor shift
    What I am looking for is the various brands and part numbers of the headers that will bolt right up WITH THE COLUMN SHIFT .. WITHOUT MODIFYING THE HEADER
    I want to order a set from Jet Hot precoated and I'll be darned if I am going to ruin a 2 or 3 hundred dollar ceramic coating or spend six months dealing with returns credits reorders and all the crap
    so I would appreciate any input you guys have for a '75 maverick with a 302 AND A COLUMN SHIFTER c4, for long tube headers which DON'T require changing to floor shift .. beating the primary tubes to half original diameter .. or pulling the engine to install them
    thanks
    PS .. economical pricing is good since apperently Summit won't take my left kidney in trade for car parts ...
  2. RegL404
    RegL404 Member
    The only ones that I know of that fit with a column shifter is Hooker super comp 6110 (they are expensive).
  3. maverick75
    i have hered you can modify the linkage to make the column work with 6901's
    i will order these in a week or two but i will change it to floor since i'm not very fond of column shifters
  4. benben
    benben Member
    Europe, Estonia, Tallinn
    Mav`75, 302, 2d, A/T, A/C
    I have 6901 with column shift, but I remod the shift linkage.Without remod it not works.I did it last summer. Now I plan to go to the floor shift, reason is, with the remod shift linkage the shifter cant go further than D , hardly go to 2-nd. When I put the headers, the engine and the gearboks rubber pads are old. Now I rebild the engine, put new pads and i want to use higher rpm shift points,but I cant shift manually. So the floor shifter is what I need.
    (sorry, english is not my native)
  5. koonswala
    koonswala Member
    Winnsboro, LA
    maverick
    only shortys will work from what i have played with one an 8 cyl. we did one on a country mavs ask him if he can get you some picks it might take him a while he is out of town ill call and see if he can get you some if you want just let me know that is why mine is all the parts that come from the ford plant well kinda lol
