headers for powersteering and column shift c4?
Discussion in 'Technical' started by jb70grabber, Feb 12, 2012.
  1. jb70grabber
    jb70grabber Member
    East windsor ct
    1970 maverick grabber 306 gt40 x heads and cam t-5 5 speed 8.8 rear 17 bullitt wheels also 76 low 22k 2dr undergoing restoration
    hi guys i havent had to ask for help in awhile but after looking at many older posts i still am a bit lost as what to do here. my 70 is finally done wich means yep time to start a new one, i scored a very low 22,000 mile 76 green 2door maverick out of ny 2 weeks ago and love it all ready, but i am swapping the 250 for a 302 i have and want to use the factory power steering and column shifter, i have nothing as far as manifolds or headers i'm using the hooker 6901s in my 70 and there great but that car has manual steering and a 5 speed, what r u guys and gals using in this type of application also if anyone has a home for this very low mileage 250 l6 motor let me know i would like to see it get a good home thanks jeff:burnout:
  2. injectedmav
    injectedmav Member
    Georgia
    I was using hooker 6901's with a floor shift car that had the interlock rod which is the same as the column shift cars, if I remember right, but the clearance was extremely tight. Most guys here that I've seen, weren't able to make them fit. I assume because of differences in the cars, but I did also do a little tweaking because I wanted to retain the shift locking feature.
  3. Craig Selvey
    Want a bolt in header with NO mods required, then get the Doug Thorley shorties.
    Any type of long tube header (unless you get custom ones made) will require a power steering drop down bracket.
