Headers for maverick
Discussion in 'Technical' started by 71maverickGT, Feb 24, 2011.
  1. 71maverickGT
    71maverickGT Member
    NY
    71 maverick gt
    iv been doing alot of research of certain headers to fit into the maverick i have a later style 302 in a 71 maverick i heard that its a nightmare to get headers to fit in this car, what headers do you guys run and think will work the best for my setup?
  2. fordman57
    fordman57 Member
    Hinton WV
    71 Comet
    Headers
    I run hedman 88300 on my 71Comet fit good with no mods
  3. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Doug Thorley shorties. Only problem was the pitman arm hit the collector on max left turn. Exhaust guy threw away the collector and made a slight S-curve in the DS pipe -- problem solved.
  4. maverick75
    As long as you have regular angle plug heads you wont have any issue with headers. Hooker 6901 are another option. Oh and if your planning to run power steering you need a drop down bracket.
  5. don graham
    Hooker 6901's. :)
  6. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Have to mention that column shift automatic linkage may create an issue with headers.
  7. 71maverickGT
    71maverickGT Member
    NY
    71 maverick gt
    thanks guys these are deff some options i will consider i swaped the car to 5 speed not done with the conversion yet but i was just worried bout the shock tower clearence
  8. dirt racer
    dirt racer Member
    southern pines NC
    70 maverick
    hooker vs hedman
    i recently replaced a set of rusted of out set hedmans for hookers. i feel the hedmans had more clearence for my 351w but the hookers are much thicker walled tubing and seem to have performance in mind much better fitting head to flange. summed up the hedman seem esier to install but the hooker 6901 are a much better looking header(looking at the performance capability). And i bought the hooker 6901 cheaper than i could find the heddman 88300.
  9. maverick75
    Headers on a 351W is a WHOLE nother story. Especially if your using 302 headers.
