Header Question
Discussion in 'Technical' started by MAVROCK 72, Jul 26, 2005.
  1. MAVROCK 72
    MAVROCK 72 New Member
    Maryland
    1972 V8 Maverick
    I am wondering if anyone knows of headers that will work on a 72 Maverick with a 302, power steering and C4 with the shifter on the columb. Any info will be greatly apreciated.
    Thanks
    MAVROCK 72
  2. maverick75
    i dont think u can use headers with a columm shifter
    you'll have to convert to a floor type
  3. maverick75
    and if u use headers you'll also have to get a drop bracket for the P.S.
  4. MAVROCK 72
    Maryland
    1972 V8 Maverick
    Thanks for the quick replys. The drop bracket is no problem, I have a left over from a 65 Mustang. My consern is the linkage down next to the steering box.
  5. RegL404
    RegL404 Member
    Hooker super comp 6110 fit with auto on column.
  6. benben
    benben Member
    Europe, Estonia, Tallinn
    Mav`75, 302, 2d, A/T, A/C
    I have super cops,column shift , but I remod the linkage. At first I tray to put the original linkage after installing headers, brain damage, then i throw away the middle part of linkage and weld together upper and lower arm of tree part linkage and bend in wright angle. Important is the upper and lower arm shud look to the same direction as they was. In other ways they dont sit back in the bushings.
  7. maverick75
    do you have these on mav -and were they hard to install?:huh:
    and were can i get me a pair i cant seem to find any
  8. maverick75
    wow they cost $599.95
    i think i'll convert to a floor and buy the chep summit ones
  9. RegL404
    RegL404 Member
    Yes I have them on my '72. I bought them new in '87. The specs seems to have changed since I got mine, 30" tubes vs 34", and 8" collector vs 10". Mine being the latter specs. They fit great. The price you got is probably coated, Summit has them for 389.95 uncoated.
