H and X pipes.....do i really need one
Discussion in 'Technical' started by Racer_X, May 20, 2010.
  1. Racer_X
    Racer_X Maverick Hugger
    North Carolina
    1974 Maverick (1970 clone)
    do i have to run an H or X pipe on my exhaust system? can i do with out it?
  2. maverick75
    No, and Yes.
  3. Bob Wiken
    Fayetteville, Arkansas
    I had a complete header back exhaust put on my car a couple of weeks ago. The exhaust guy reccomened not to use an H pipe unless I was racing a lot.
  4. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    I don't know from personal experience but a friend that does told me an X-pipe would quiet the pipes some. I've read there's a tiny pick up in HP. So, when I saw a 2.5" scratch and dent X-pipe at Carlisle for $20 I bought it, not for the HP but in hopes it will tone down the exhaust a little.
  5. rthomas771
    X-pipe is for high rpm like NASCAR. H-pipe is more for low to mid rpm like for a street car. If you're running 8000 rpm for hours at a time go with the X-pipe. If you stay around 4000 rpm go with the H-pipe. I like the sound of an unbalanced exhaust, it sounds more old school.
  6. scooper77515
    Quick answer is NO, you don't need one.
  7. scooper77515
    I too like the unbalanced sound, on a dual-pattern cam, on true dualled exhaust.
  8. PaulS
    No, you don't need a cross-over pipe. It will give you better mileage, and a tad more torque if properly installed. Yes you can get along quite nicely without it.
  9. Jsarnold
    '72 Sprint
  10. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    That's about right. I have an X-pipe and it's a bit more "mellow" sounding than glasspacks ought to be. No less aggressive really, still sounds good, just doesn't sound quite as loud as "true dual" glasspacks usually do. Doesn't sound like a single pipe either... It's hard to explain, kinda has its own sound. I do get lots of positive comments about it though.
  11. David74maverick
    David74maverick Member
    Arizona
    '74 maverick, '87 Celica
    they just ballance out your exhaust. not a 100% neccisary but it's one of those things that can make something good a little better. I have a H-pipe on my exhaust and coming from true duals the sound is just a little more consistant, where the pattern was a little off before (4,2 and 7,8 in the fire order), now some of the two in a row sound gets shared to the other side...
  12. scooper77515
    Re-awakening this thread rather than starting a new one.
    Getting tired of my Flowmaster Super44 drone. I am sure I can tackle installation of an H-Pipe in my garage.
    Where in the length of the tubes is the best place to install it to cancel out my drone (please, no difficult mathematical forumulas!!!!)
    I think I will make it out of 2 slip-on pieces so I can still separate my two exhaust halves for easy removal/installation.
  13. Streamliner
    Streamliner Member
    Best way i've heard this described is that an H pipe is more muscle car sounding and an X pipe is more european sounding....I had an X on my '05 GTO and loved the sound....Mellow and not obnoxious...Kinda more high pitched than the H
  14. scooper77515
    I don't think I want the X on this setup, just because I like to be able to yank my exhaust off one piece at a time, and if I weld a slip-on chunk to each side, I can still take it apart easily.
    I don't want to have to use the "spray-paint and run it wide open" method to find where to install the H, since I am not at the track and don't need a speeding or endangerment ticket right now.
    So, who has one that seems to work, and where along the length did you install it?
  15. Joe Dirt
    Put it within 12" or so of the collectors and usually where it clears best.
