GT40's on an 86 302
Discussion in 'Technical' started by JHodges, Jun 18, 2008.
  1. JHodges
    JHodges thumper
    Dora Alabama
    I have an 86 302 out of a T-bird or a lincoln. It has a roller cam. I can buy rebuilt GT40 heads for $400. I was told it would not work because the 86 pistons had no valve reliefs. Would it work.
  2. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    Yes they will you need to watch the duration of the cam and ratio of the rocker arms to ensure that the pistons will not contact the valves.
  3. EFIMAV
    EFIMAV Member
    Davenport Iowa
    I know several people that have run B-cams with this combo. Be sure you have good valve spings (not stock), maybe run a thicker head gasket as well
  4. scooper77515
    I have a similar setup, but with valve reliefs, and there is LOTS of extra room on mine, and I have a pretty big cam in there. I would guess that it would be safe to not have the reliefs.
    It is really easy to test it before you run it. Get a degreeing kit or buy a very light valve spring and put it on the valves, and slowly rotate the engine by hand and test how much clearance you have when the piston is up.
  5. newtoford
    newtoford Member
    New Castle Delaware
    i thought it was only the grand marques that had the flat pistons?
  6. EFIMAV
    EFIMAV Member
    Davenport Iowa
    86 mustangs also, this was a unique year for the first year EFI mustang, intakes, heads and TBs (among other things) were year specific, 87 saw several changes for the mustang not sure about the crown vic etc.
  7. tim keck
    sharps chapel,Tn
    My Comet has an '86 shortblock(mustang)w/E7 heads and a B303 cam,got about 10,000 miles on it w/no problems.
  8. baddad457
    The 5.0's with E6SE heads got the no valve relief pistons, this included the 85 Stang, T-Birds, Cougars, Lincoln Town Car, Marquis and Crown vics. The big cars had these heads & pistons till the end of the 5.0's in em in 1991. There were a few pickups with em too.
  9. bmcdaniel
    You always need to check piston-to-valve clearance when making a change like this. No one can tell you if your parts are gonna clear. Heads may have been milled, block decked, etc. You have to measure. DO NOT gain clearance by using a thicker head gasket. You want to keep the squish/quench clearance between the piston and head deck between .035" - .050" or the engine could be detonation prone.
  10. MFG Racing Team
    MFG Racing Team Member
    São Paulo, SP Brazil
    A whole bunch of Mavs in differente set-ups, from road race cars, to restomod and absolutelly original vehycles.
    Always...ALWAYS check PTV clearance. If you need help on that, let me know and I'll send you a step by step procedure.
    Ham
