Grille turn signal wiring
Discussion in 'Technical' started by Jefflee347, Jun 7, 2015.
  1. Jefflee347
    Jefflee347 Member
    1970 Ford Maverick
    hi guys, I'm hoping someone can help me. I want to ditch my original turn signals below the bumper and wire up the ones in the grille. Unfortunately the ones in the grille have a different pig tail. Anyone know if I can simply swap pig tails with the original ones? I tried one of the splice things but it was drawing too much power and neither one would work. Any advise would help. Thanks
  2. 71gold
    did you have them grounded?
  3. Jefflee347
    Jefflee347 Member
    1970 Ford Maverick
    I'm not sure if I need too. I just used one of those plastic wire splices that splices both wires together without cutting them in half. I might just end up taking it to an auto electric shop:/
  4. mercgt73
  5. 71gold
    those also could be your problem...:yup:
    Jefflee347 likes this.
  6. 71gold
  7. 71gold
    I changed my lower ones to fog lights and the grille ones for park/turn...:thumbs2:
  8. mercgt73
  9. Jefflee347
    Jefflee347 Member
    1970 Ford Maverick
    That's exactly what I want to do!
  10. Jefflee347
    Jefflee347 Member
    1970 Ford Maverick
  11. Jefflee347
    Jefflee347 Member
    1970 Ford Maverick
    Frank, can you give me any suggestions on what bulbs to use to turn the original turn signals into fog lights? Also did you just wire it up separately with a toggle switch or something? Thanks
  12. Jefflee347
    Jefflee347 Member
    1970 Ford Maverick
    Success gentleman! Thanks for all the help! I ended up buying the correct pig tails from Autozone and the rest was a piece of cake! The wiring was basically the same:)
  13. Jefflee347
    Jefflee347 Member
    1970 Ford Maverick
    Dang! I spoke too soon. The turn signals now work but when I turn the lights on the turn signal indicator lights on the dash stay on. Also they won't work with the lights on and the parking lights don't work:/
  14. 71gold
    I think some years the parking lights are off when the lights are on...:yup:
  15. 71gold
    I put a clear 1157 bulb in the bumper lights, then they were wired to the high/low beam headlights. the fog lights are on bright when the low beams are on and on low when the highs are on.
