Greetings...
Discussion in 'New Members Forum' started by yellowgrabber, Aug 28, 2006.
  1. yellowgrabber
    yellowgrabber Member
    Camano Island, WA
    72 Maverick Grabber, 61 Falcon Futura V8 363ci Dart Block, 62 Falcon V8 289ci toploader
    First, I would like to commend you on the site … very well done.
    I’ll start with some background. I’ve owned, since new, a ’72 Maverick Grabber that started life with a 302 and a C4 automatic. It’s yellow and originally had the orange strips. The car went through several changes mainly between the years 1972 and 1976. And it was always my daily driver.
    The first changes, based on memory (this was more than 30 years ago), was the following:
    1972-73
    · Weiand dual plane hi-rise intake
    · Holley 735cfm 4-barrel w/vacuum secondary’s
    · Headers (Doug Thorley I think)
    · Dual exhaust
    · Ford Hi-Perf cam (hydraulic with anti-pump up lifters)
    · Shift kit and cooler for the C4 automatic
    · Ford Torino/Mustang “GT” wheels w/chrome rings
    · Sears under dash aftermarket A/C
    I had to relay quite a bit on what info Ford released and what other Maverick owners knew then, which was little much compared to now.
    1973-74
    · Cobra 2-4 barrel aluminum intake
    · 2 – 625cfm Carter AFBs
    · Electric fuel pump
    · Crane cam (still hyd but more lift and duration… can’t remember specs)
    · Accel dual point distributor and wires and large yellow coil
    · 351 W heads ported and polished and milled .030… screw-in studs installed w/ guides and hardened pushrods
    · 9” rear end from 57 Ford wagon (3.89 gears I think)
    · 4.86:1 gears most of the time though I did run 5.67s at the strip once… what a mistake even with tall slicks
    · Ford 2.78 Toploader from a 64 ½ Mustang after destroying a few C4s
    · Performance clutch setup
    · Hurst shifter
    · American Racing wheels… I think 14” front and 15” rear with BF Goodrich T/A Radials as the last set of tire mounted about 20 years ago and still on the car until a couple years ago
    1974-83 (basically as it remains presently…)
    · Edelbrook “Torquer” single plane hi-rise aluminum intake manifold
    · Various Holley carbs from 500cfm 2-barrel to 750cfm double pumper and even a 950cfm 3-barrel… it has a 650cfm double pumper on it now
    · 3.25 gears
    · Isky cam (milder)
    · Heavy duty (not hi-performance) pressure plate & clutch…
    · Painted bright yellow, no strips
    In 1984 I left the Maverick in the capable hands of a good friend, telling him it would only be for a year or two while I went overseas… 22 years later I’m still overseas and up until a couple years ago it was still in my friend’s garage just as I left it. Two years ago I bought a house north of Seattle and finally returned my friend his garage space and moved the car to my garage.
    During my vacations back to WA over the last two years I have found time to completely rebuild the front suspension including the power steering. Also lower it about an inch and added ’76 Maverick disc brakes. I rebuilt the old Toploader, Hurst shifter and rear end, adding a 4 pinion traction lock. I replaced the original ’57 rear brakes with modern 11” self-adjusting drums. Also replaced the intake with a RPM Air Gap and replaced carb with a Holley Street Avenger 570cfm. Finally, I replaced the old wheels with 16” Centerlines. Still lots to do.
    What did I miss? Hopefully didn’t go overboard.
    I’ve got plenty of questions… there may be a 5 speed in the future and addressing sloppy power steering.
    Thanks...
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Cool story! Now that is a friend when he stores your car for 22 years.
  3. don graham
    great story. sounds like a neat car. welcome to the board.:Welcome:
  4. Mavaholic
    Great Story!!!!!!! Welcome to the board. Hope to see some pictures soon.
  5. Dave B
    :Welcome: Neat story, but we really need pic's.
  6. boss9
    boss9 Member
    Akron,Ohio
    77 4-door 250 I6
    :Welcome: Cool story. 22 yr. storage, that's a friend indeed !!
  7. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Welcome and cool story.
    Dan
  8. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    welcome aboard
  9. awannabegrabber
    awannabegrabber Always Learning
    Wichita, Kansas
    1976 Maverick with a trim package
  10. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    'Great history on your treasure of a car.
    Welcome to the site.
  11. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    welcome to the board~!
  12. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    :Welcome: to the board cant wait to see some pics:drive:
  13. maverick75
    :Welcome:great story
  14. yellowgrabber
    Camano Island, WA
    Many thanks... I'll find some pics to post. And try to figure out how. :huh:
  15. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    :Welcome: :dance: :yippee: GLAD YOU ARE HERE
