Granada Rotors PBR Calipers
Discussion in 'Technical' started by Phil, Dec 17, 2016.
  1. Phil
    Phil Member
    Southern NJ
    1975 For Maverick
    Has anyone used the newer mustang 2 Piston calipers with the granada setup? I see it's easy to make a bracket and have them work, and I'm planning to do it
    Questions:
    1) Will the stock manual master cylinder (i believe it has a 15/16" bore?) be sufficient?
    2) For those who have done this, how do you like it? I'm looking for better brake actuation, clamping power with R4-S pads is more than sufficient with the current calipers, so as long as it's comparable.
    Link: http://www.fastfairlane.com/Tech Tips/Brakes/Mustangcailpers/index-mustangcailpers.html
  2. Phil
    Phil Member
    Southern NJ
    1975 For Maverick
    This seems to be lightly treaded territory. Once I do it I shall report back on my findings, so others with the granada setup can learn from my successes and (hopefully few) failures. If anyone wishes, I can even do a writeup with pictures.
  3. mojo
    Sounds like something I might be interest to me.
  4. Phil
    Phil Member
    Southern NJ
    1975 For Maverick
    Excellent. I received the calipers today, and I am VERY impressed by their design and size. These will be a great upgrade over the outdated granada design for sure. I will start a separate writeup thread after I've completed the job. It will probably be a month or two before that happens
