Grabber Hood
Discussion in 'General Maverick/Comet' started by John A Fasig, Mar 14, 2004.
  1. John A Fasig
    John A Fasig Member
    over here now
    several plastic and tin
    What year or years did the grabber hoods have the
    "allygater eye's" on them? Well they aint air scoop's.
  2. DanielRoush
    DanielRoush Member
    none
    none
    I think they only had it for 2 years. 1971 and 1972 were the only years they had those hoods.
  3. MaverickGrabber
    Cardington, ohio
    1972 Maverick Grabber 393w
    71-72 only ....and you can drill the holes and make them work like real scoops
  4. qicvick
    qicvick Member
    ft.worth,tx
    1972 grabber
    I have a 69 judge that has almost the same scoops that have little flapper doors behind the scoops( which are open) which open when you pull a little knob marked ram air under the dash, the regular goats without ram air have scoops that are closed like the Mavericks, THey are a little different but had to have been made by same vendor as Fords
