Grabber Hood Question
Discussion in 'General Maverick/Comet' started by vern, Jun 10, 2007.
  1. vern
    vern Member
    New Jersey
    I just took a closer look at the scoops on my grabber hood. I noticed that the scoops are decorative only.(solid no air can pass through) I thought they introduced air to the intake area to increase hp. Do I have the wrong scoops or do I need to modify them??
  2. maverick75
    they were never functional...although maverick man is woking on a carbon fiber version that will have the scoops intergrated and will be functional.
  3. don graham
    what you see is what you get. they're for looks only.:)
  4. Sam M.
    Sam M. Just a nobody
    Southern NJ
    Vern, all of them are supposed to be like that, decorative only. My opinion would be to leave them that way as opening them will add very little in the way of increased airflow unless you also build ducts and even then I doubt those small opening amount to any real benefits.
    The second Grabber hood I bought actually had the fake honeycomb missing - someone took a dremel tool or something similar and opened the entire scoop. I didn't like it so I got some plastic honeycomb from the grille of a Dodge (gasp!) truck and glued it behind the hole to restore the original look.
  5. vern
    vern Member
    New Jersey
    Ok I just thought they were functional..No problem they are fine then thanks....
  6. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Man, I remember when I was 16 and decided I would see a horsepower increase when I took the scoops out one bored day. I really expected a seat of the pants feel with those out. Makes me laugh now.
    Dan
  7. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    i woulda thought each scoop was worth at least 100hp:D
  8. 20cows
    20cows Member
    West Texas
    74 Maverick
    What about the scoops I've seen on the Comet GT? They look like they would make a practical difference If there was a hole. Are the GT factory scoops just for show as well?
    (Never seen one up close).
  9. newtoford
    newtoford Member
    New Castle Delaware
    yeah there just for show too. its just bolted to a stock comet hood. i can tell you they would have alot more potential though since they flow alot better. my scoop is pretty simmular and is functional. it does give me a little bit of pick up even on a 6
  10. draggon13
    draggon13 Member
    Hilliard, Florida
    1974 Maverick V8 5 Speed
    But I'll be danged if they don't look GOOD!(y)
    rk
  11. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    That's because you didn't have 3-inch exhausts to help flow all that increased air...
