Grabber Grille Question
Discussion in 'General Maverick/Comet' started by actionrpm, Mar 12, 2009.
  1. actionrpm
    actionrpm Differential specialist
    western pa.
    '70 mav. '40 Ford Pickup '72 Bronco '06 SuperDuty V-10
    Got my grilles out today to start getting one ready,one is black with red and chrome Mav emblem,"sport lamps"with pot metal bezels ,and yellow lens,it also had metal brackets on the back of the lamps.The other grille is silver with plastic "sport lamps" with clear lens,no metal brackets,and twist out sockets that had daul filement bulbs.The black grille sockets do not twist out.I know that '71 Grabbers had clear lens and ran a yellow bulb,were they the plastic bezal style and did the metal brackets come on both designs? Also did the real Grabber Sport Lamps have a single filament bulb,or they use a double but just used the bright side? Want it to look original '71 Grabber if possible.
  2. rayzorsharp
    The first one would be correct and they use single filament bulbs.
  3. Dave B
    The plastic lamps with the twist out sockets, showed up in 75 or 76.
  4. actionrpm
    western pa.
    One problem,the plastic clear lens's do not fit the pot metal style bezals....
  5. Dave B
    They don't, you can buy repoped 70 Mustang ones. They fit.
  6. actionrpm
    western pa.
    Thanks Dave...Jack
  7. Grabber71
    Grabber71 Milique Toast
    Vancouver Island, Canada
    '71 Grabber Maverick 351w
    I agree..except my Grabber uses the double filament bulb..but only one filament lights up. Is this unique? Never thought there would be any differences...
  8. rayzorsharp
    You know, I think they all do. For some reason I thought it was a single filament since it is a single function light but it does seem like it takes an 1157 bulb. My bad!
  9. actionrpm
    western pa.
    Cool!! Then I have the correct lamps and not the newer turn signals...
  10. 19Grabber72
    19Grabber72 Member
    Cedar Falls, Iowa
    1972 Maverick 2 Door Sport Sedan Grabber
    Yep! 1157 bulbs are the ones in my '72 sport lamps--the lens is clear, bulbs yellow and pot metal frames (blk) around.
