Good ol' engine swap
Discussion in 'Technical' started by alexzoinks, Apr 13, 2005.
  1. alexzoinks
    alexzoinks New Member
    Portland, OR
    72 Two door 200 c4. 74 Four door 250
    This might sound like a simple question, but are there any snags that I might encounter in swapping out a 200 with a 250? The 250 is coming out of the 74 with a 3 speed manual. It's going into the newly acquired 72 with a c4.
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I'd like to buy the 250 z-bar, frame side and engine side mounts from you ... Thanks ...
    All these parts ....
  3. dmhines
    Cumming, GA
    I'd also like to buy the flywheel .. how many miles on it?
  4. dmhines
    Cumming, GA
    To answer your original question ... The C4 is different on the 200 than on a 250. You will need either a 250 or 302 backing plate and C4 tranny .... and starter as well ... 250 also used the larger 250/302 radiator ...
  5. elliot
    elliot Member
    Boubon MO
    76 4 door 347 paxton and t56
    You will need the 250/302 (351 , 289 , 300 ect.) C4 bellhousing and dust shield (backing plate) . You can use the 200 c4 on the 250 but take it easy on it. You can prolly get by with using the 200 rad with the 250 depending on how hot it gets where you live. You will need to use the 250 motor mounts as well because it is wider than the 200 .
    I don`t know if you have any plans on moddin the 250 but here is a web site with all kinds of cool inline ford hop up parts to drool over :) www.fordsixparts.com and a good inline forum www.fordsix.com
