headed off to work this morning, goin to pick me up a distributor for my ldo today so i can put the steel gear on in the press at work. do i need to heat the gear up before i press it on the distributor shaft??
Heat up the gear will help BUT just get the gear good and warm and Don't warm up the shaft KEEP IT cool.
well had hell getting my roll pin out of the new model dis, and hell getting the steel gear off. no problem getting the roll pin and gear off of the points dis. only to find that the distributors i have have two different diameter shafts and the points dis shaft is WAY to small for the steel gear. not from heat because i didnt use any
